AD707_超低漂移运算放大器_英文版
消耗积分:0 | 格式:zip | 大小:297KB | 2016-03-31
lydia301
分享资料个
The AD707 is a low cost, high precision op amp with state-ofthe-art performance that makes it ideal for a wide range of precision applications. The offset voltage spec of less than 15 mV is the best available in a bipolar op amp, and maximum input offset current is 1.0 nA. The top grade is the first bipolar monolithic op amp to offer a maximum offset voltage drift of 0.1 mV/°C, and offset current drift and input bias current drift are both specified at 25 pA/°C maximum.
评论(0)
发评论
下载排行榜
