AT89S52_8位微控制器的在系统可编程Flash 8K字节_英文版
消耗积分:0 | 格式:zip | 大小:208KB | 2016-03-31
于鸿斌
分享资料个
The AT89S52 is a low-power, high-performance CMOS 8-bit microcontroller with 8K bytes of in-system programmable Flash memory. The device is manufactured using Atmel’s high-density nonvolatile memory technology and is compatible with the industry- standard 80C51 instruction set and pinout. The on-chip Flash allows the program memory to be reprogrammed in-system or by a conventional nonvolatile memory programmer.
评论(0)
发评论
下载排行榜
