动力调谐陀螺八位置法漂移测试与数据分析
消耗积分:5 | 格式:rar | 大小:135 | 2009-08-15
安德森大
分享资料个
采用 8 位置法对某型号动调陀螺漂移进行测试 ,讨论了测试系统的组成和分析测试
过程以及应用最小二乘估计对测试数据的处理方法.通过测试来找出误差源以提高测试精度 ,使得测试数据更加接近陀螺的实际情况.通过分析陀螺的漂移误差 ,寻求合适的补偿方法以减小其影响.
关键词 : 动力调谐陀螺;8 位置法漂移测试;最小二乘法
Abstract :The major parts of testing system ,the procedure for drift testing and the
method of processing the data were analyzed by using eight position to test dynamically
tuned gyroscope. The errors caused by various factors can be found through the test and
the data are more reliable. The appropriate measurement can be designed through analyzing
the gyro drift so as to reduce the negative effect.
Key words :dynamically tuned gyroscope ;eight position ;drift testing ;least square
estimate
评论(0)
发评论
下载排行榜
