OP290,pdf datasheet (Dual Oper
消耗积分:3 | 格式:rar | 大小:185 | 2009-08-28
张生
分享资料个
The OP290 is a high performance micropower dual op amp that operates from a single supply of 1.6 V to 36 V or from dual supplies of ±0.8 V to ±18 V. Input voltage range includes the negative rail allowing the OP290 to accommodate input signals down to ground in single-supply operation. The OP290 output swing also includes ground when operating from a single supply, enabling zero-in, zero-out operation.
评论(0)
发评论
下载排行榜
