LT3507 pdf
消耗积分:2 | 格式:rar | 大小:655 | 2008-06-30
挽你何用
分享资料个
The LT®3507 is a triple, current mode, DC/DC converter
with internal power switches and a low dropout regulator.
The switching converters are step-down converters capable
of generating one 2.4A output and two 1.5A outputs. All
three converters are synchronized to a single oscillator.
The 2.4A output runs with opposite phase to the other two
converters, reducing input ripple current. Each regulator
has independent shutdown and soft-start circuits, and
generates a power good signal when its output is in regu-
lation, easing power supply sequencing and interfacing
with microcontrollers and DSPs.
The switching frequency is set with a single resistor yielding
a range of 250kHz to 2.5MHz. The high switching frequency
allows the use of small inductors and capacitors resulting
in a very small triple output supply. The constant switching
frequency, combined with low impedance ceramic capaci-
tors, results in low, predictable output ripple. With its wide
input voltage range of 4V to 36V, the LT3507 regulates a
broad array of power sources including 5V logic rails,
unregulated wall transformers, lead acid batteries and
distributed power supplies.
评论(0)
发评论
下载排行榜
