ADA4412-3,pdf datasheet (Cutof
消耗积分:3 | 格式:rar | 大小:378 | 2009-09-04
彭友旺
分享资料个
The ADA4412-3 is a comprehensive filtering solution designed to give designers the flexibility to easily filter and drive various video signals, including high definition video. Cutoff frequen-cies of the sixth-order video filters range from 9 MHz to 36 MHz and can be selected by two logic pins to obtain four filter combinations that are tuned for RGB, high definition, and standard definition video signals. The ADA4412-3 has a rail-to-rail output that can swing 4.5 V p-p on a single 5 V supply.
评论(0)
发评论
下载排行榜
