AD9283,pdf datasheet (3VAD Con
消耗积分:3 | 格式:rar | 大小:252 | 2009-09-05
分享资料个
The AD9283 is an 8-bit monolithic sampling analog-to-digital
converter with an on-chip track-and-hold circuit and is optimized
for low cost, low power, small size and ease of use. The
product operates at a 100 MSPS conversion rate, with outstanding
dynamic performance over its full operating range.
The ADC requires only a single 3.0 V (2.7 V to 3.6 V) power
supply and an encode clock for full performance operation. No
external reference or driver components are required for many
applications. The digital outputs are TTL/CMOS compatible
and a separate output power supply pin supports interfacing
with 3.3 V or 2.5 V logic.
评论(0)
发评论
下载排行榜
