设置ldc1312_4_ldc1612_4和ldc1101传感器驱动器配置
消耗积分:1 | 格式:rar | 大小:280 KB | 2016-12-05
张瑾
分享资料个
TI’s multichannel inductance-to-digital converters (LDCs) LDC1612, LDC1614, LDC1312 and LDC1314 feature an adjustable sensor current-drive to set the sensor amplitude. The LDC1101, a high-speed
device, also has an equivalent set of controls. The optimal current-drive of these devices is sensordependent and is based on the sensor parallel resistance at the sensor resonant frequency, R
P. A sensor
with a lower R
P needs a higher current-drive than one with a higher RP. This application note explains how an appropriate IDRIVE setting can be selected by analyzing the sensor signal with an oscilloscope, which is usually the most straight-forward method.
评论(1)
发评论
yuan6023008 2020-11-19
0 回复 举报
学习 学习 111 收起回复
下载排行榜
全部1条评论
