AD7951,pdf datasheet (Programm
消耗积分:3 | 格式:rar | 大小:557 | 2009-09-09
绝代双骄
分享资料个
The AD7951 is a 14-bit, charge redistribution, successive
approximation register (SAR) architecture analog-to-digital
converter (ADC) fabricated on Analog Devices, Inc.’s iCMOS
high voltage process. The device is configured through hardware or via a dedicated write only serial configuration port for input
range and operating mode. The AD7951 contains a high speed
14-bit sampling ADC, an internal conversion clock, an internal reference (and buffer), error correction circuits, and both serial and parallel system interface ports. A falling edge on CNVST
samples the analog input on IN+ with respect to a ground sense, IN−. The AD7951 features four different analog input
ranges and three different sampling modes: warp mode for the
fastest throughput, normal mode for the fastest asynchronous
throughput, and impulse mode where power is scaled with throughput. Operation is specified from −40°C to +85°C.
评论(0)
发评论
下载排行榜
