AD7724,pdf datasheet (Modulato
消耗积分:3 | 格式:rar | 大小:288 | 2009-09-09
分享资料个
This device consists of two seventh order sigma-delta modulators.
Each modulator converts its analog input signal into a high
speed 1-bit data stream. The part operates from a 5 V power
supply and accepts a differential input range of 0 V to +2.5 V or
±1.25 V centered about a common-mode bias. The analog inputs
are continuously sampled by the analog modulators, eliminating
the need for external sample-and-hold circuitry. The input
information is contained in the output stream as a density of
ones. The original information can be digitally reconstructed
with an appropriate digital filter.
评论(0)
发评论
下载排行榜
