AD7400A,pdf datasheet (Isolated Sigma-Delta Modulator)
消耗积分:5 | 格式:rar | 大小:584 | 2009-09-11
王银喜
分享资料个
The AD1886A contains an internal microphone preamp with 20 dB gain; in most cases a direct microphone connection as shown in
Figure 16 is adequate. If the microphone level is too low, an external preamp can be added as shown in Figure 17. In either case the
microphone bias can be derived from the codec’s internal reference (VREFOUT) using a 2.2 kΩ resistor. For the preamp circuit, the
VREFOUT signal can also provide the midpoint bias for the amplifier.
评论(0)
发评论
下载排行榜
