MAX3272, MAX3272A,pdf datashee
消耗积分:3 | 格式:rar | 大小:433 | 2009-09-18
分享资料个
The MAX3272/MAX3272A 2.5Gbps limiting amplifiers
accept a wide range of input voltages and provide a
constant-level output voltage with controlled edge
speeds. Additional features include power detectors
with programmable loss-of-signal (LOS) indication, an
optional squelch function that mutes the data output signal
when the input voltage falls below a programmable
threshold, and an output polarity selector. These parts
exhibit excellent jitter performance and have low power
dissipation.
The MAX3272/MAX3272A feature current-mode logic
(CML) data outputs that are tolerant of inductive connectors,
and are available in a 4mm ✕ 4mm QFN package
or in die form (MAX3272 only). Along with the
MAX3271, the MAX3272/MAX3272A are ideal for lowpower,
compact optical receivers.
Applications
Gigabit Ethernet Optical Receivers
Fibre Channel Optical Receivers
System Interconnects
2.5Gbps Optical Receivers
SONET/SDH Receivers
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
