ADN2830,pdf datasheet (Average
消耗积分:3 | 格式:rar | 大小:522 | 2009-09-23
417804
分享资料个
The ADN2830 provides closed-loop control of the average
optical power of a continuous wave (CW) laser diode (LD)
after initial factory setup. The control loop adjusts the laser
IBIAS to maintain a constant back facet monitor photodiode
(MPD) current and thus a constant laser optical power. The
external PSET resistor is adjusted during factory setup to set
the desired optical power. RPSET is set at 1.23/IAV, where IAV
is the MPD current corresponding to the desired optical power.
Programmable alarms are provided for laser fail (end of life)
and laser degrade (impending fail).
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
