ADN2870,pdf datasheet (Laser D
消耗积分:3 | 格式:rar | 大小:541 | 2009-09-23
吴藩
分享资料个
The ADN28701 laser diode driver is designed for advanced SFP and SFF modules, using SFF-8472 digital diagnostics. The device features dual-loop control of the average power and extinction ratio, which automatically compensates for variations in laser characteristics over temperature and aging. The laser needs only to be calibrated at 25°C, eliminating the expensive and time consuming temperature calibration. The ADN2870 supports single-rate operation from 50 Mbps to 3.3 Gbps or multirate operation from 155 Mbps to 3.3 Gbps.
评论(0)
发评论
下载排行榜
