ADN2872,pdf datasheet (Laser D
消耗积分:5 | 格式:rar | 大小:520 | 2009-09-23
靓仔峰
分享资料个
The average power and extinction ratio can be set with a voltage provided by a microcontroller DAC or by a trimmable resistor. The part provides both bias and modulation current
monitoring, as well as fail alarms and automatic laser shutdown.
The ADN2872, a SFF-/SFP-compliant laser diode driver, can
work with the Analog Devices, Inc., ADuC7019/ADuC702x
MicroConverter® family and the ADN289x limiting amplifier
family, to form a complete SFP/SFF transceiver solution. The ADN2872 is available in a space-saving 4 mm × 4 mm LFCSP
specified over the −40°C to +85°C temperature range.
评论(0)
发评论
下载排行榜
