ADM2483,pdf datasheet (Isolate
消耗积分:5 | 格式:rar | 大小:225 | 2009-09-25
分享资料个
The ADM2483 differential bus transceiver is an integrated,
galvanically isolated component designed for bidirectional data
communication on balanced, multipoint bus transmission lines.
It complies with ANSI EIA/TIA-485-A and ISO 8482: 1987(E).
Using Analog Devices’ iCoupler technology, the ADM2483
combines a 3-channel isolator, a three-state differential line
driver, and a differential input receiver into a single package.
The logic side of the device is powered with either a 5 V or 3 V
supply, and the bus side uses a 5 V supply only.
评论(0)
发评论
下载排行榜
