MAX6603,pdf datasheet (RTD-to-
消耗积分:5 | 格式:rar | 大小:223 | 2009-09-27
刘艳
分享资料个
The MAX6603 dual-channel, platinum RTD-to-voltage
signal conditioner excites and amplifies the signal from
two external 200Ω platinum-resistive temperature
devices (Pt RTD) to achieve high-voltage, level-filtered
signals for temperature measurements. The MAX6603
provides a direct ratiometric output voltage to simplify
the interface to microcontrollers with integrated analogto-
digital converters (ADCs). External precision resistors
and calibration processes are not needed. The
MAX6603 provides the necessary signal-conditioning
functions, including ratiometric excitation current,
amplification, buffered voltage outputs, diagnostic fault
detections, and input protection. The MAX6603 amplifies
signals from two RTDs operating over the -40°C to
+1000°C temperature range and provides the temperature
information as two independent analog voltages.
The MAX6603 features a ±6°C (max) accuracy over the
+400°C to +600°C temperature range.
The MAX6603 has overvoltage protection up to +16V
on RTD inputs, and ±5kV electrostatic discharge (ESD)
protection at RTD input pins for reliable operation
where RTD temperature-sensing probes are used. The
MAX6603 monitors the RTD for faults and asserts the
respective DG output low for fault conditions. The analog
voltage outputs can be readily connected to a variety
of microcontrollers.
The MAX6603 is available in a small, 10-pin TDFN-EP
package and operates over the -40°C to +125°C automotive
temperature range from a single +3V to +5.5V
power supply.
Applications
Automotive Exhaust Temperature Monitoring
Engine Control Management to Meet EURO IV
Regulations
Braking Systems
Industrial Temperature Sensors
Food Transportation Monitoring Systems
Industrial Process Measurements
评论(0)
发评论
下载排行榜
