LM5041,pdf datasheet (Cascaded
消耗积分:3 | 格式:rar | 大小:555 | 2009-09-29
分享资料个
The LM5041 PWM controller contains all of the features
necessary to implement either current-fed or voltage-fed
push-pull or bridge power converters. These “Cascaded”
topologies are well suited for multiple output and higher
power applications. The LM5041’s four control outputs include:
the buck stage controls (HD and LD) and the pushpull
control outputs (PUSH and PULL). Push-pull outputs are
driven at 50% nominal duty cycle at one half of the switching
frequency of the buck stage and can be configured for either
a guaranteed overlap time (for current-fed applications) or a
guaranteed both-off time (for voltage-fed applications).
Push-pull stage MOSFETs can be driven directly from the
internal gate drivers while the buck stage requires an external
driver such as the LM5102. The LM5041 includes a
high-voltage start-up regulator that operates over a wide
input range of 15V to 100V. The PWM controller is designed
for high-speed capability including an oscillator frequency
range up to 1 MHz and total propagation delays of less than
100ns. Additional features include: line Under-Voltage Lockout
(UVLO), soft-start, an error amplifier, precision voltage
reference, and thermal shutdown.
评论(0)
发评论
下载排行榜
