LM337L,pdf datasheet (3-Termin
消耗积分:5 | 格式:rar | 大小:551 | 2009-10-05
分享资料个
The LM337L is an adjustable 3-terminal negative voltage
regulator capable of supplying 100mA over a 1.2V to 37V
output range. It is exceptionally easy to use and requires
only two external resistors to set the output voltage. Furthermore,
both line and load regulation are better than standard
fixed regulators. Also, the LM337L is packaged in a standard
TO-92 transistor package which is easy to use.
评论(0)
发评论
下载排行榜
