LMH6570,pdf datasheet (2:1 Hig
消耗积分:2 | 格式:rar | 大小:551 | 2009-10-08
世态薄凉
分享资料个
The LMH™6570 is a high performance analog multiplexer
optimized for professional grade video and other high fidelity
high bandwidth analog applications. The output amplifier
selects one of two buffered input signals based on the state
of the SEL pin. The LMH6570 provides a 400 MHz bandwidth
at 2 VPP output signal levels. Multimedia and high
definition television (HDTV) applications can benefit from the
LMH6570’s 0.1 dB bandwidth of 150 MHz and its 2200 V/μs
slew rate.
评论(0)
发评论
下载排行榜
