ADC083000,pdf datasheet (8-Bit
消耗积分:5 | 格式:rar | 大小:551 | 2009-10-10
听风说梦
分享资料个
The ADC083000 is a single, low power, high performance
CMOS analog-to-digital converter that digitizes signals to 8
bits resolution at sampling rates up to 3.4 GSPS. Consuming
a typical 1.9 Watts at 3 GSPS from a single 1.9 Volt supply,
this device is guaranteed to have no missing codes over the
full operating temperature range. The unique folding and interpolating
architecture, the fully differential comparator design,
the innovative design of the internal sample-and-hold
amplifier and the self-calibration scheme enable an excellent
response of all dynamic parameters up to Nyquist, producing
a high 7.0 Effective Number Of Bits, (ENOB) with a 748 MHz
input signal and a 3 GHz sample rate while providing a 10-18
Word Error Rate. The ADC083000 achieves a 3 GSPS sampling
rate by utilizing both the rising and falling edge of a 1.5
GHz input clock. Output formatting is offset binary and the
LVDS digital outputs are compatible with IEEE 1596.3-1996,
with the exception of an adjustable common mode voltage
between 0.8V and 1.15V.
评论(0)
发评论
下载排行榜
