AP1515,pdf,datasheet (150KHz,
消耗积分:5 | 格式:rar | 大小:233 | 2009-10-19
分享资料个
The AP1515 series are monolithic IC designed for a step-down DC/DC converter, and own the ability of driving a 1.5A load without additional transistor component. Due to reducing the number of external component, the board space can be saved easily.
The external shutdown function can be controlled
by logic level and then come into standby mode.
The internal compensation makes feedback control
have good line and load regulation without external
design. Regarding protected function, thermal
shutdown is to prevent over temperature operating
from damage, and current limit is against over
current operating of the output switch. If current
limit function occurred and VFB is down to 0.5V
below, the switching frequency will be reduced.
The AP1515 series operates at a switching
frequency of 150KHz thus allowing smaller sized
filter components than what would be needed with
lower frequency switching regulators. Other
features include a guaranteed +4% tolerance on
output voltage under specified input voltage and
output load conditions, and +15% on the oscillator frequency. The output version included fixed 3.3V and an adjustable type.
评论(0)
发评论
下载排行榜
