The traditional way to control the output of multiple LEDs is to dedicate a pulse width modulation (PWM) controller to each LED and use the controller to transform the input voltage to a current that supplies the LED. Often voltage controlled PWM controllers are used for this purpose. A current sense resistor is placed in series with the LED that feeds a voltage back to the controller. In essence, the controller is operating in a voltage mode holding the sample voltage constant, thereby, maintaining a constant current. This typical arrangement is shown in Figure 1.
