Abstract: The NCP5602 double LED driver includes the capability to remotely control either the normal backlight or the icon function. Moreover, when running the back light mode, the chip has a sixteen steps output current adjustment function to accurately set up the LED brightness. These functions are controlled by a standard I2C protocol as briefly depicted in the NCP5602 data sheet. This Application Note gives a software example to control all the functions embedded into the chip from a basic eight bit micro controller. The assembler code can be ported to other MCU, assuming the basic instructions are available in such MCU. I2C PROTOCOL: BASIC CONCEPT The I2C, an acronym for Interface Interchange Chip, has been developed by Philips semiconductors more than 25 years ago. The concept is built on a serial communication, using one clock line to synchronize the data flow, the second line being a bi−directional open drain dedicated to the data content. The two lines are identified as: − SCL Serial Clock Line − SDA Serial Data Line The data are based on a byte format with a rate up to 400 kHz for the standard I2C, and up to 3 MHz for the new
