1. General description The TDA8559T is a stereo amplifier that operates over a wide supply voltage range from 1.9 V to 30 V and consumes a very low quiescent current. This makes it suitable for battery fed applications (2 × 1.5 V cells). Because of an internal voltage buffer, this device can be used with or without a capacitor connected in series with the load. It can be applied as a headphone amplifier, but also as a mono amplifier with a small speaker (25 Ω), or as a line driver in mains applications. 2. Features n Operating voltage from 1.9 V to 30 V n Very low quiescent current n Low distortion n Few external components n Differential inputs n Usable as a mono amplifier in Bridge-Tied Load (BTL) or stereo Single-Ended (SE) n Single-ended mode without loudspeaker capacitor n Mute and Standby mode n Short-circuit proof to ground, to supply voltage (< 10 V) and across load n No switch on or switch off clicks n ESD protected on all pins
