TDA8941/TDA8941P pdf datasheet
消耗积分:3 | 格式:rar | 大小:777 | 2008-07-15
131594
分享资料个
c
c
1. General description
The TDA8941P is a single-channel audio power amplifier with an output power of
1.5 W at an 16 Ω load and a 9 V supply. The circuit contains a Bridge Tied Load
(BTL) amplifier with an all-NPN output stage and standby/mute logic. The TDA8941P
comes in a 8-pin dual in-line (DIP8) package. The TDA8941P is printed-circuit board
(PCB) compatible with all other types in the TDA894x family. One PCB footprint
accommodates both the mono and the stereo products.
2. Features
n Few external components
n Fixed gain
n Standby and mute mode
n No on/off switching plops
n Low standby current
n High supply voltage ripple rejection
n Outputs short-circuit protected to ground, supply and across the load
n Thermally protected
n Printed-circuit board compatible.
3. Applications
n Mains fed applications (e.g. TV sound)
n PC audio
n Portable audio.
评论(0)
发评论
下载排行榜
