The ADL5365 utilizes a highly linear doubly balanced passive mixer core along with integrated RF and LO balancing circuitry to allow for single-ended operation. The ADL5365 incorporates an RF balun allowing for optimal performance over a 1700 to 2200 MHz RF input frequency range using low-side LO injection. (Pin compatible parts for high side injection are also available). The balanced passive mixer arrangement provides LO to RF leakage better than -25dBm, and excellent intermodulation performance. The balanced mixer core also provides extremely high input linearity allowing the device to be used in demanding cellular applications where in-band blocking signals may otherwise result in the degradation of dynamic performance. For low voltage applications, the ADL5365 is capable if operation at voltages down to 3V with substantially reduced current.
