AD8113,pdf datasheet (Audio/Vi
消耗积分:5 | 格式:rar | 大小:156 | 2009-10-26
刘埃生
分享资料个
The AD8113 is a fully buffered crosspoint switch matrix that
operates on ±12 V for audio applications and ±5 V for video
applications. It offers a –3 dB signal bandwidth greater than
60 MHz and channel switch times of less than 60 ns with 0.1%
settling for use in both analog and digital audio. The AD8113
operated at 20 kHz has crosstalk performance of –83 dB and
isolation of 90 dB. In addition, ground/power pins surround all
inputs and outputs to provide extra shielding for operation in
the most demanding audio routing applications. The differential
gain and differential phase of better than 0.1% and 0.1°, respectively,
along with 0.1 dB flatness out to 10 MHz, make the
AD8113 suitable for many video applications.
评论(0)
发评论
下载排行榜
