PMBus兼容的降压DC/DC模块提供更高的输出电流
除了驱动系统板上的电压轨的数量,最新的FPGA和微处理器也要求更高的输出电流从紧凑的电源包用于供电他们。管理这种复杂的系统板超出了传统的模拟为基础的集成电源解决方案的能力。这种复杂性需要更高层次的系统智能和先进的数字电源管理能力,包括遥测和系统监控,以确保近100%的正常运行时间。据分析,一个电信系统或路由器下行的经济影响是非常高的。例如,如果一个电信系统或路由器不运行,由于电源故障,从网上零售商的网上采购可以在传输过程中丢失,使停机时间昂贵的事务为零售商。
为了满足这些市场需求的Intersil已经准备好50完全封装数字DC/DC电源模块,PMBus兼容。isl8272m标记,它是一个完整的降压直流/直流转换器模块,提供50个输出电流电压,可以改变从0.6 V的输入电压范围为4.5 V至14 V至5 V,换句话说,它的目的是提供更高的输出电流从使用行业标准的12 V或5 V输入Rails的一个紧凑的封装。在现实中,它扩展了以前的25个和33个isl8270m isl8271m数字电源模块,给用户一个简单的迁移路径的高电流电源模块在宽工作温度范围的紧凑型封装。
Integrated module
Integrated in this module are a high-performance digital PWM controller, dual-phase power MOSFETs, inductors, and passives as shown in Figure 1. The dual-phase architecture combined with high-performance MOSFETs, proprietary inductor design, and optimized package helps the DC/DC module deliver up to 50 A from a single compact package with high-power conversion efficiency. According to Jian Yin, senior applications engineering manager for Industrial Power Products at Intersil, the ISL8272M combines unique technologies and component selection to achieve a 50 A output current capability in a compact form factor. Said Yin: “High-performance FETs, proprietary inductor design, optimized package structure, and excellent thermal dissipation contribute to lowering the conduction, switching, and core losses of the device and allow the ISL8272M to deliver its full 50 A output current over a wide-operating-temperature range without requiring any air flow.”
