降压升压型DC / DC处理宽输入电压范围
一个降压升压型DC / DC转换器提供一个调节输出电压,即使当输入电压低于或高于所要求的负载。降压-升压转换器充分满足了电池供电的消费设备的需要,在所需的输入范围相当狭窄;在许多情况下,从1.8到5.5伏直流电。然而,情况是不同的,当涉及到工业和汽车应用中,输入电压可以在很宽的范围内变化。
例如,汽车电池对电源来说是最具挑战性的输入之一。虽然它的标称电压可以从10.6到15 V,根据电池的充电状态,环境温度,和发电机,冷曲柄条件可以推低于4 V的轨道和线路瞬变可以产生40 V尖峰。这意味着它可以从小于4 V到超过40 V。此外,专家说,汽车动力轨也受到各种动态干扰所产生的变化,发动机,过渡负荷,电感瞬变线束。
To address the needs of industrial and automotive applications, power semiconductor suppliers such as Intersil, Linear Technology, andTexas Instruments, among others, have developed a variety of low-noise, high-performance, wide-input buck-boost DC/DC converters. As a result, a variety of products are available that can help power designers confront the challenges of generating a stable output voltage using a single low-cost inductor, despite very wide fluctuations in the input voltage range.
