实时网络化照明控制设计
照明系统变得越来越复杂,LED照明的引入,需要直流电源和专门的驱动程序,为控制个人灯光和增强人机界面和用户体验开辟了新的可能性。事实上,早期关于“物联网”的猜测,以及什么新类型的设备可能有自己的IP地址,并连接到互联网,认为灯泡是最好的例子。当然,将有线或无线网络控制器电路嵌入灯泡中的技术是可行的,而且可能具有成本效益。然而,这是一个技术寻找市场的案例,还是对这种类型的解决方案有真正的需求?或者,是否有一种替代的、更直接的和较低成本的解决方案?
本文首先旨在了解为什么从传统白炽灯和荧光灯转变为LED改变控制动态。然后看看可能的解决方案,开始与那些可以简单地复制传统的墙壁开关与灯具之间的实时连接,探索提供了更为灵活的人机界面使用网络连接选项之前,类似的场景,通过物联网专家预期。
为了提出这些解决方案,本文将参考来自不同厂家的一些产品。这将主要集中在网络设备,通常这些协议嵌入在低端微控制器(MCU)如德克萨斯仪器cc2533单片机的ZigBee技术,其msp430bt5190蓝牙单片机与以太网,或Microchip的PIC18器件。它还将包括必要的模拟前端设备如TI的afe031和模块级的解决方案,如Skyworks sky65337-11 ZigBee射频收发器和hdg104-dn-2 Wi-Fi模块从H和D无线。
What is different about controlling LED lights?
Most commercial and domestic lighting is powered by mains electricity, operating from AC supplies that are predominantly either 220 to 240 V at 50 Hz (in Europe, most of Asia and Africa, and parts of South America) or 100 to 127 V at 60 Hz (in USA/Canada and some other countries)。 This is not a problem for incandescent bulbs or fluorescent tubes, which are readily designed to operate directly at these voltages and frequencies. In fact, the characteristic operating principle of fluorescent lamps, including compact fluorescent lamps (CFLs), actually requires the use of an AC supply together with a series ballast (inductor) to limit current flow and avoid the destructive, runaway situation that would result from using a DC supply.
