The PWM control circuit is able to adjust theduty ratio linearly from 0 to 100%. An enable function, an over current protection functionis built inside. When second current limit function happens, the operation frequencywill be reduced from 150KHz to 50KHz. An internal compensation block is built in tominimize external component count.
