将能量收集传感器集成到Linux网关
消耗积分:0 | 格式:rar | 大小:0.14 MB | 2017-06-28
分享资料个
  将能量收集传感器集成到Linux网关
  当EnOcean把无电池无线模块的第一代市场,他们最独特的特点–如20 NA唤醒定时器–必须建在复杂的离散模拟电子电路。近年来,EnOcean开发海豚芯片集成的超低功耗无线能量采集接口和微控制器。
  这些自供电设备通过无线网络连接,或者通过USB链路连接到中央网关。该网关可以由Linux操作系统提供中央协调和控制。这是建立家庭或工业自动化的自供电网络的关键因素。
  中医300模块是针对线路供电器、中继器和网关和stm300设计用于能源收割机驱动的传感器和执行器。
  igure 1: The STM300 low power module from EnOcean for a network powered by energy harvesting.
  The TCM transceiver modules allow line powered actuators, repeaters, and gateways to be built. The module provides several built-in operating modes for serial communication, or switching and dimming of output loads. In addition, repeater functionality (1 or 2 level) can be activated. The TCM 300 and TCM 320 offer two different mounting options. TCM 300 can be mounted as an SMD component on a host PCB while the TCM 320 is designed for vertical mounting using a pin connector.
  The power saving RF transmitter module, the STM300 from EnOcean, enables wireless and maintenance-free sensors and actuators such as room operating panels, motion sensors or valve actuators for heating control. Power is provided by an external energy harvester such as a small solar cell or a thermal harvester that uses the Peltier effect. An energy storage device can be connected externally to bridge periods with no supply from the energy harvester. A voltage limiter avoids damaging the module when the supply from the energy harvester gets too high.
评论(0)
发评论
下载排行榜
