电信交换机中高功率因数的保持
电信应用中的电力传输系统现在必须处理大电流的大CPU阵列,可能消耗数百瓦的电力。为了提高效率,电信电源采用开关拓扑转换电供应48伏直流输出,然后分发给其他系统的线路卡。问题在于开关电源由于输入电路的结构而对电网呈现非线性阻抗。
输入电路通常包括半波或全波整流器,接着是存储电容器,该电容器维持电压接近输入正弦波峰值电压的值。它是由随后的半波充电的。这种拓扑只在栅极供电峰值时从输入中提取电流;这个脉冲包含足够的能量来维持负载直到下一个峰值。电流脉冲的持续时间不超过周期的四分之一,脉冲期间所提供的电流必须至少是平均电流的四倍。
与正弦输入相比,产生的电流波形被大量强谐波严重扭曲。只有基本分量产生实际功率,剩余的峰值负责表观功率。这种差异用功率因数表示,除纯正弦波外,所有的情况都小于功率因数。
The harmonic distortion has an adverse effect on other loads on the same supply. The distorted current causes additional heating in the wires and electrical distribution gear. As a result, legislation has come in worldwide to limit the harmonic distortion of switched-mode PSUs, in addition to controls imposed by the utilities themselves on high-power equipment. Electrical equipment with an input power requirement of 75 W or more, supplied in Europe and Japan, must comply with the IEC61000-3-2 standard. The standard specifies the maximum amplitude of line-frequency harmonics up to and including the 39th harmonic. As core telecom switches are responsible for high loads, they need to limit harmonic distortion and maintain a high power factor.
