Low Power Off line Digital PWM
消耗积分:5 | 格式:rar | 大小:228 | 2009-11-11
挽你何用
分享资料个
The iW1692 is a high performance AC/DC power supply controller which uses digital control technology to build peak current mode PWM flyback power supplies. The device provides high efficiency along with a number of key built-in protection features while minimizing the external component count and bill of material cost. The iW1692 removes the need for secondary feedback circuitry while achieving excellent line and load regulation. It also eliminates the need for loop compensation components while maintaining stability over all operating conditions. Pulse-by-pulse waveform analysis allows for a loop response that is much faster than traditional solutions, resulting in improved dynamic load response. The built-in power limit function enables optimized transformer design in universal off-line applications and allows for a wide input voltage range.
评论(0)
发评论
下载排行榜
