医疗设计项目的传感器解决方案
医学不进步科技,科技进步医学。这是在诊断、维修尤其如此,为阻断和预防医学监测技术。传感器技术,特别是基于微型化的改进,尤其是MEMS领域的改进,处于领先地位。MEMS芯片感知压力,检测运动(或缺乏),识别和测量力,泵液,控制流,等等。
传感器被植入,通过切口进入导管,或用于体腔;外部传感器用于接触体液和医疗器械。
今天的植入式传感器非常小,重量轻,坚固耐用,足以在很长一段时间内使用。今天的医疗传感器能够区分行走、跑步和其他体力活动。考虑到电源在某些设计中是一个问题,例如心脏起搏器,压电式聚合物传感器是微型的、可靠的,而且除了它们可以使用的环境之外,无需任何动力。同样,植入式传感器也可以通过射频技术以RF能量棒的形式在外部进行供电。当魔杖与天线和应答器一起完成时,就被用来接近传感器,传感器醒来进行测量,通过射频链路将数据发送给棒,然后返回到睡眠模式。
Sensors placed by way of an incision, for example, attached to a catheter, are used to measure blood flow in the heart. These types of sensors are typically used in the short term, spanning minutes to hours.
Disposable silicon MEMS pressure sensors are used during the childbirth process to measure contraction frequency and pressure, and are removed after the baby is born. Disposable oral and rectal probes are used to measure body temperature.
Sensors that are exposed to fluids include disposable blood pressure sensors typically used during surgical procedures to monitor blood pressure. These sensors are replaced regularly. The sensor module is plugged into a monitor and logs all extracted information.
