The SM73306 amplifier was specifically developed for single supply applications that operate from −40°C to +125°C. This wide temperature range makes it well-suited for photovoltaic systems.
The SM73306 rail-to-rail input is complemented by rail-to-rail output swing. This assures maximum dynamic signal range which is particularly important in 5V systems.
Ultra-low input current of 150 fA and 120 dB open loop gain provide high accuracy and direct interfacing with high impedance sources.
