CMOS 3.0V Core Serial Peripheral Interface (SPI) with Multi-I/O – SPI Clock polarity and phase modes 0 and 3 – Double Data Rate (DDR) option – Extended Addressing: 32-bit address – Serial Command set and footprint compatible with S25FL-A, S25FL-K, and S25FL-P SPI families – Multi I/O Command set and footprint compatible with S25FL-P SPI family READ Commands – Normal, Fast, Dual, Quad, Fast DDR, Dual DDR, Quad DDR – AutoBoot – power up or reset and execute a Normal or Quad read command automatically at a preselected address – Common Flash Interface (CFI) data for configuration information Programming (1.5 Mbytes/s) – 512-byte Page Programming buffer – Quad-Input Page Programming (QPP) for slow clock systems Erase (0.5 Mbytes/s) – Uniform 256-kbyte sectors Cycling Endurance – 100,000 Program-Erase Cycles, minimum Data Retention – 20 Year Data Retention, minimum.
