The ADXL78 is a low power, complete single-axis accelerometer with signal conditioned voltage outputs that are on a single monolithic IC. This product measures acceleration with a fullscale range of ±35 g, ±50 g, or ±70 g (minimum)。 It can also measure both dynamic acceleration (vibration) and static acceleration (gravity)。 The ADXL78 is the fourth-generation surface micromachined iMEMS® accelerometer from ADI with enhanced performance and lower cost. Designed for use in front and side impact airbag applications, this product also provides a complete costeffective solution useful for a wide variety of other applications. The ADXL78 is temperature stable and accurate over the automotive temperature range, with a self-test feature that fully exercises all the mechanical and electrical elements of the sensor with a digital signal applied to a single pin. The ADXL78 is available in a 5 mm × 5 mm × 2 mm, 8-terminal ceramic LCC package.
