DESCRIPTIONS z The Super Bright Yellow device is made with AlGaInP (on GaAs substrate) light emitting diode chip z Electrostatic discharge and power surge could damage the LEDs z It is recommended to use a wrist band or anti-electrostatic glove when handling the LEDs z All devices, equipments and machineries must be electrically grounded FEATURES z 1.6 mm x 0.8 mm SMD LED, 0.65 mm thickness z Low power consumption z Wide viewing angle z Ideal for backlight and indicator z Package: 4000 pcs / reel z Moisture sensitivity level: 3 z RoHS compliant
