This equipment has been tested and found to comply with the limits for a Class A
digital device, pursuant to part 15 of the FCC Rules. These limits are designed to
provide reasonable protection against harmful interference when the equipment
is operated in a commercial environment. This equipment generates, uses, and
can radiate radio frequency energy and, if not installed and used in accordance
with the instruction manual, may cause harmful interference to radio
communications. Operation of this equipment on a residential area is likely to
cause harmful interference in which case the user will be required to correct the
interference at his/her own expense.
Any unauthorized changes or modifications to this equipment would void the users
authority to operate this device.
