LVDS应用程序和数据手册
消耗积分:1 | 格式:pdf | 大小:2623KB | 2017-10-27
张宇·
分享资料个
LVDS等信号介绍,包括信号标准等。
  Data transmission, as the name suggests, is a means of moving data from one location to another. Choosing the best transmission standard to accomplish this requires evaluation of many system parameters. The first two considerations encountered are How fast? and How far? How fast? refers to the signaling rate or number of bits transmitted per second. How far? is concerned with the physical distance between the transmitter and receiver of the data. Consideration of these two primary system parameters usually results in a significant narrowing of the possible solutions. Figure 1–1 shows the speed and distance coverage of some familiar data transmission choices.
LVDS应用程序和数据手册
评论(0)
发评论
下载排行榜
