研究基于VxWorks嵌入式实时系统下M 总线控制系统的软件设计思想和实现方法.该系统需要设置两个各自独立运行的实时任务. 达到对外部设备进行控制的功能.第1个任务负责收集命令和通过传感器采集到的数据,并设定命令优先级;第2个任务负责解释执行,并发送命令执行后的啊应,两个任务之间通过命令缓存链表进行锺信.此设计思想简单、高效,可以被广泛应用在与M 总线相关的其他控制系统中.
Proposes a new"software designing idea and method of implementation for M bus
control system based on VxW orks embedded real—time systems.In oIdeI to realize the function of controlling the device,two real—time tasks are set.The one gathers the command and the data collected by sensor,and set the priority:the other runs the command and feeds back the result to the device that needs the result.They communicate by a command buffer link between them.The method used in this paper is simple and highly efficient and can be used in other kinds of control systems related with the M bus system .
