MM54HC365/MM74HC365 Hex TRI-STATEÉ Buffer MM54HC366/MM74HC366 Inverting Hex TRI-STATE Buffer MM54HC367/MM74HC367 Hex TRI-STATE Buffer MM54HC368/MM74HC368 Inverting Hex TRI-STATE Buffer General Description These TRI-STATE buffers are general purpose high speed inverting and non-inverting buffers that utilize advanced silicon- gate CMOS technology. They have high drive current outputs which enable high speed operation even when driving large bus capacitances. These circuits possess the low power dissipation of CMOS circuitry, yet have speeds comparable to low power Schottky TTL circuits. All 4 circuits are capable of driving up to 15 low power Schottky inputs. The MM54/74HC366 and the MM54/74HC368 are inverting buffers, where as the MM54/74HC365 and the MM54/ 74HC367 are non-inverting buffers. The MM54/74HC365 and the MM54/74HC366 have two TRI-STATE control inputs (G1 and G2) which are NORed together to control all six gates. The MM54/74HC367 and the MM54/74HC368 also have two output enables, but one enable (G1) controls 4 gates and the other (G2) controls the remaining 2 gates. All inputs are protected from damage due to static discharge by diodes to VCC and ground.
