74LS75 pdf datasheet
消耗积分:5 | 格式:rar | 大小:133 | 2008-08-06
分享资料个
DM54LS75/DM74LS75 Quad Latches
General Description
These latches are ideally suited for use as temporary storage
for binary information between processing units and input/
output or indicator units. Information present at a data
(D) input is transferred to the Q output when the enable is
high, and the Q output will follow the data input as long as
the enable remains high. When the enable goes low,
the information (that was present at the data input at the
time the transition occured) is retained at the Q output until
the enable is permitted to go high.
These latches feature complementary Q and Q outputs
from a 4-bit latch, and are available in 16-pin packages.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
