5475/DM5475/DM7475 Quad Latches General Description These latches are ideally suited for use as temporary storage for binary information between processing units and input/ output or indicator units. Information present at a data (D) input is transferred to the Q input when the enable (G) is high, and the Q output will follow the data input as long as the enable remains high. When the enable goes low, the information (that was present at the data input at the time the transition occurred) is retained at the Q output until the enable is permitted to go high. These latches feature complementary Q and Q outputs from a 4-bit latch and are available in 16-pin packages. Features Y Alternate Military/Aerospace device (5475) is available. Contact a National Semiconductor Sales Office/Distributor for specifications.
