The AAT1210 is a high power DC/DC boost (step-up) converter with an input voltage range from 2.7 to 5.5V. The output voltage can be set from VIN + 0.5V to 18V. The total solution is less than 1mm in height. High operating efficiency makes the AAT1210 the ideal solution for
battery powered and consumer applications.
