AAT3175,pdf datasheet(For Whit
消耗积分:3 | 格式:rar | 大小:221 | 2010-01-30
贾永世
分享资料个
The AAT3175 is a low noise, constant frequency charge pump DC/DC converter that uses a tri-mode load switch (1X), fractional (1.5X), and doubling (2X) conversion to maximize efficiency for white LED flash applications. The AAT3175 is capable of driving up to three flash LEDs at 300mA total current from a 2.7V to 5.5V input. A low external parts count (two 1μF flying capacitors and two small 1μF capacitors at VIN and VOUT) make this part ideally
suited for small battery-powered applications.
评论(0)
发评论
下载排行榜
