AAT3527,pdf datasheet(MicroPow
消耗积分:5 | 格式:rar | 大小:223 | 2010-02-01
手托初梦
分享资料个
members of AnalogicTech's Total Power Management IC™ (TPMIC™) product family. These microprocessor reset circuits are ideal for monitoring voltage supplies in portable systems, where extended battery life is critical. They provide a reliable, lowcost solution by eliminating external components. The AAT3526/7/8 products operate by monitoring the system power supply voltage. When the input voltage drops below a fixed threshold, the device
asserts a reset signal for a minimum of 150ms after VCC has risen back above the fixed threshold. They are guaranteed to operate down to 1.2V and designed to ignore fast line transients appearing on VCC. The AAT3526/7/8 series is available with three output stage versions: AAT3526 push-pull active low output; AAT3527 push-pull active high output;
and AAT3528 open drain active low output. The quiescent supply current is extremely low, typically 1μA, making this device ideal for portable batteryoperated equipment.
评论(0)
发评论
下载排行榜
