针对燃料电池动态响应上的不足,本文探讨了燃料电池发电系统中的能量管理设计方法,重点讨论了能量管理控制系统的结构和控制器的设计。建立了5kW 燃料电池发电系统,通过实验验证了所设计的能量管理控制系统的有效性。 Abstract: Fuel cell is known as a slow dynamic response application. In this paper, an energy management design in a Fuel Cell power system is discussed to solve the limitation. The structure, arithmetic and the controller design of the energy management system is discussed. Finally, the experiment results on a 5 kW fuel cell power system with energy management are given to verify the theoretical analysis. 关键词:燃料电池,能量管理,超级电容 Keywords:Fuel Cell,Energy Management,Super Capacitor
